1994 Honda Del Sol Pulls Left After Curb
GUITARJONES07
  • 8 POSTS
I hit a curb pretty much with the front left wheel when I hydroplaned last night.. now it pulls to the left. Is there any way I can tell if the axle is bent? I think its just the wheel.. which needed replacing anyway. But I just want to know how i might be able to tell if the axle is bent, so I know much money I'm going to end up spending on this. THANKS!
Jan 12, 2007 at 1:15 AM
BRUCE HUNT
  • 3,754 POSTS
Do the rim and get the tire taken care of. I suspect that you have got a donut on the vehicle. It drives but pulls to the left. The chances of bending the axle or CV axle is not very good. You would have taken out the strut etc before the axle would bend. I am sitting hundreds of miles from you no doubt. Take the car to an alignment specialist that you trust and have them look at the front end. They can give you an estimate before working on it. They can easily see what is wrong. Your speed and the level of impact play a major factor in what is wrong with the vehicle. It could just be in need of an alignment.
Let us know what you find out.
Jan 12, 2007 at 1:23 AM
GUITARJONES07
  • 8 POSTS
Thanks a bunch. I was probably going about 35.. and the curb was about 4 inches. Its not too far off.. if i hold the wheel straight its going straight.. I'm not compensating to the right or anything like that..Am I okay to drive on it for a couple of days? or will i die? LoL.. Seriously though, i can't get it fixed until next week and i need to get to work.. (45 minute drive) I just don't want to do any extra damage..
Jan 12, 2007 at 1:30 AM
BRUCE HUNT
  • 3,754 POSTS
Get a new rim and a tire. You will probably see some possible wear to the tires being out of alignment. You might even feel some shaking in the steering wheel but driving it does not sound so bad based on your last posting. Just drive carefully and get the work done as soon as possible. I suspect the alignment should be all you need.
Jan 12, 2007 at 1:33 AM
GUITARJONES07
  • 8 POSTS
I can't thank you enough.. Now I won't get screwed around by any mechanic on this one cause i know what is wrong. Thanks again!
Jan 12, 2007 at 1:38 AM
Suggested Repair
Replace the damaged rim and tire, then have a trusted alignment shop inspect the front end and align it. A bent axle is unlikely; a hard impact would more often damage the strut or suspension first. Drive carefully until the work is done.
Conversation Summary
The owner of a 1994 Honda Del Sol hit a curb with the front left wheel at about 35 mph and the car now pulls left. They asked how to tell if the axle is bent and whether it is safe to drive until repairs next week. The expert said axle damage is unlikely and recommended replacing the rim and tire, then having an alignment specialist inspect the front end. Based on the described impact, careful driving until the alignment is done should be acceptable.
