1993 del sol clutch info
1993 ALL OTHER MAKES ALL OTHER MODELS
GUITARJONES07
  • 8 POSTS
i'm pretty sure my 1993 del sol has a hydraulic clutch system, when i push in the pedal it goes all the way to the floor with no resistance and kinda sticks to the floor for a few seconds before it pops up.. i refilled the fluid, which was empty.. but that didn't help.. is there anything else i can troubleshoot and try to fix myself?
thanks!
Mar 21, 2007 at 6:36 AM
GUITARJONES07
  • 8 POSTS
might i have a bubble in the line? how can i tell.. what do i do ?
Mar 21, 2007 at 6:41 AM
BRUCE HUNT
  • 3,754 POSTS
Follow the line from the master where you added the fluid and right as it gets to the tranny it will enter into the slave unit. There should be a bleeder on the line at the slave. Try bleeding the system. You will need a partner to help with this. Now don't rule out that one of the two, either master or slave units may have failed. Look for fluid leaks. Look along the line, around the slave, around the master and inside the car where the clutch pedal linkage goes through the firewall.
Mar 21, 2007 at 8:15 AM
GUITARJONES07
  • 8 POSTS
i fixed the prob.. thanks all.. just had to refill the fluid and pump it...
Mar 21, 2007 at 11:09 AM
