2001 Hyundai Accent Clutch Pedal Freeplay
2001 ALL OTHER MAKES ALL OTHER MODELS
SHIREK
How difficult to adjust clutch. Where is adjustment located?
Feb 3, 2007 at 9:24 AM
BRUCE HUNT
  • 3,754 POSTS
You know I don't believe there is any adjustment as the old cable or push rod type clutch systems had. What is the problem you are experiencing?
Feb 4, 2007 at 2:12 PM
SHIREK
I just need to remove somef the freeplay in the pedal
Feb 7, 2007 at 5:59 AM
DBARRAS
Hydraulic clutch, no cable
Feb 7, 2007 at 7:57 AM
BRUCE HUNT
  • 3,754 POSTS
Have you checked the fluid level in the reservoir and the play on the pedal as in a loose connection of the pedal? It is possible you have early stages of a master or slave going out.
Feb 7, 2007 at 8:15 AM
Suggested Repair
This hydraulic clutch has no cable or pushrod adjustment. Check the reservoir fluid level and pedal linkage for looseness or excess play. Excess freeplay may indicate an early master or slave cylinder failure.
Conversation Summary
The owner of a 2001 Accent asked how hard it is to adjust the clutch and where the adjustment is, wanting to remove some pedal freeplay. Replies noted it is a hydraulic clutch with no cable. The expert said there is no traditional adjustment and advised checking fluid level and pedal connection play, as a master or slave cylinder may be starting to fail.
