2001 Hyundai Accent Jerks Below Half Tank
2001 HYUNDAI
AEPORTELLO
My Hyundai Accent 2001 seems to begins to jerk whenever the gas gauge goes below a half a tank. Whenever I fill the tank up it does not do it. I recently replaced the fuel filter thinking that was the problem and it worked for about a week or so. No there is some sort of humming coming from the feul pump when it is going to do this. Please help.
Mar 20, 2006 at 11:34 AM
PEPPERMRJ
  • 1,158 POSTS
Welcome tot he forum. :)
Sound like the fuel pump is failing. Have the pressure tested at the rail.
Good luck and let us know.
Mar 22, 2006 at 10:36 AM
Suggested Repair
Have fuel pressure tested at the rail. The symptoms point to a failing fuel pump.
Conversation Summary
The owner of a 2001 Hyundai Accent reports jerking when the fuel gauge drops below half a tank, which stops after filling the tank. A fuel filter replacement helped only briefly, and a humming noise now comes from the fuel pump before the jerking starts. The expert says the fuel pump is likely failing and recommends testing fuel pressure at the rail.
