1995 Hyundai Accent Brake Pedal to Floor
be sure that you get it repair as soon as possible brakes its the most important thing in the vehicle.
Suggested Repair
With the car in park and the engine off, press the brake pedal with moderate pressure. If the pedal slowly sinks to the floor, replace the master cylinder, which is likely leaking past its internal seals. Have the brakes repaired immediately before driving.
Conversation Summary
The owner of a 1995 Hyundai Accent said the brake pedal suddenly lost resistance and went to the floor on the freeway. Pumping restored only partial pedal, and the parking brake was used to avoid a crash. A dealer inspection about four months earlier had recommended a rear brake kit but found the rest of the system fine. The expert advised testing whether the pedal slowly sinks with the engine off, which would indicate an internally leaking master cylinder that should be repaired as soon as possible.
