1994 Honda Accord Temperature Gauge Erratic
POZOR
Honda Accord 94
My temperature gauge on the dash board is acting weird.
It will not ever go to the normal temp area it kinda stays halfway up after the car is been working for a while and will stay there for some time then will drop down to zero even with the car still driving and go back halfway up and so on!
Thank you!
Mar 13, 2007 at 11:26 AM
  • 31,937 POSTS
Hi there,
I would check that the terminal to the temp sender is tight & clean, if thats ok replace the sender as these are the most common cause for your problem.
Mark (mhpautos)
Mar 15, 2007 at 1:06 PM
Suggested Repair
Check that the temperature sender terminal is tight and clean. If the connection is good, replace the temperature sender, the most common cause of this gauge behavior.
Conversation Summary
The owner of a 1994 Honda Accord reports the temperature gauge stays about halfway up after driving, then drops to zero while the car is still moving and later rises again. The expert advises checking that the temperature sender terminal is tight and clean, and replacing the sender if the connection is fine.
