1991 Honda CRX White Exhaust Smoke
Suggested Repair
Change the oil and inspect it for fuel odor or coolant contamination, such as a brown tint, foamy appearance, or sweet smell. White smoke is more consistent with coolant entering the engine than with a rich mixture; failing fuel injectors were also mentioned as a possible cause.
Conversation Summary
The owner of a 1991 CRX reports white tailpipe smoke only when the engine is throttled, not at idle, and was told it smelled like fuel. Experts note that fuel smoke is usually not white and ask whether the car is using coolant or oil. A later reply says the white smoke does not smell like gas. An expert explains that white smoke often indicates coolant mixed with oil, identifiable by a sweet smell, and that failing fuel injectors are another possibility. The recommended next step is an oil change and inspection of the oil for a fuel smell or a brown, foamy, sweet-smelling appearance.
