1988 Honda CRX No Fuel Delivery
JOSHCUMMINGS04
i just bought a 1988 honda crx hf 1.5 liter. it had sit for 3 years and i couldnt get it to start due to bad fuel pump. i replaced the fuel pump with a brand new one and im still not getting any fuel to the engine.. any ideas would be a great help.. thank you
Apr 10, 2006 at 11:42 PM
LOSONE
  • 1,616 POSTS
Sounds like you might have a bad EFI relay. It is located way up in the top of the dash on the left side. It is a common Honda $125.00 problem. Good luck
Apr 12, 2006 at 6:04 AM
Suggested Repair
Check the EFI relay at the top left of the dash. A failed relay is a common Honda issue that can stop fuel delivery even after the fuel pump is replaced.
Conversation Summary
The owner of a 1988 Honda CRX HF that sat for three years replaced the fuel pump but still gets no fuel to the engine. The expert suggests checking the EFI relay high in the left side of the dash, a common Honda failure.
