1984 Honda CRX Timing Adjustment Off
Take off the timng belt. Make sure that both valves are closed on number one cyl by gentle rocking the cam back and forth.. DO NOT rotate the cam as the valves will hit the pistons and cause damage.
Make a mark on the cam gear so you can use it as a reference point. Before you put the belt on make sure the tensioner doesn't pull the cam off angle.
Good luck
insure cam sprocket dot or arrow is in 12: o'clock position and that the groves on back of cam sprocket is aligned with head. position #1 pistion at TDC first
make sure crank sprocket timing mark and cam sprocket timing mark are parallel to one another.
Put distributer back to center and pull cord :lol: I hope this is of help.
TIP: use oil dipstick to guage TDC position be carefull and make sure dipstick is on top of piston and not to either side.
GOOD LUCK.
Suggested Repair
Confirm true TDC on cylinder 1 with a thin screwdriver or dipstick on the piston crown, then compare cam-gear timing marks between the original and replacement heads. With the belt still on, align the distributor drive and crank marks; remove the belt only after both No. 1 valves are closed, and do not rotate the cam. Mark the cam gear as a reference, keep the tensioner from pulling the cam off angle, and reinstall the belt so the crank and cam marks stay parallel before centering the distributor.
Conversation Summary
After a head-gasket job and a later head swap on a 1984 Honda CRX 1.5 carbureted engine, the owner could only get the engine to run with the Hitachi distributor nearly fully advanced, not centered in its slot. The crank TDC mark and cam sprocket appeared aligned, but timing light checks showed the white TDC mark rather than the red mark at the pointer. Experts said the belt or distributor drive may be off by a tooth or two, and that cam timing marks can differ between heads. They advised verifying absolute TDC, confirming both No. 1 valves are closed, marking the cam gear, and reinstalling the belt without letting the tensioner move the cam.
