Civic ignition timing is backwards
OH95VX
  • HONDA CIVIC
This is a 1995 Civic VX, 1.5 liter vtec-E, 5-speed manual, 174,000 miles. Long, long story coming up, so please bear with me.
For over a year I had a worsening steady speed miss after warmup (ran fine in open loop). It always smoothed out when accelerating, so I suspected the oxygen sensor (it was still the original) was sluggish, and running too lean when the engine was in lean-burn.
Before I got around to changing the O2S, the coil and igniter failed. Had it towed to a shop and they changed coil and igniter. From that day forward the car also ran poorly under acceleleration when warm.
Replaced 02 sensor, cap, rotor, plugs. It ran much better, but still had a slight stumble on acceleration. This stumble gradually worsened over about 6 weeks.
Now it runs poorly under load, with a very noticable miss and slugghishness on acceleration and hill climbing. If I jab the throttle at idle, the engine coughs; I can hear the miss in the exhaust.
All this happens AFTER warmup. Again, it seems to run fine when in open loop.
The CEL is NOT on, and NO trouble codes have been set except from my experiments with disconnecting sensors.
Plugs were black with carbon after only 2000 miles. Replaced with fresh dealer plugs of correct type.
There's a bit of carbon on the base of the oxygen sensor. (Hope it's not fouled - $$$)
Here's where it gets weird.
I got out the timing light and found that the ignition timing is being RETARDED about 10-15 degrees when I blip the throttle. I've never seen another engine that had its timing retarded when the throttle was opened. I can't find another VX to compare, but a friend's '93 Civic DX advances quite a bit with the same conditions.
After this initial retard when throttle is snapped open, timing quickly falls back to the base value (16 deg BTC), and advances only slightly with slowly increasing RPM.
I suspect the "backwards" and sluggish timing is what's causing the poor driveability, but I can't figure out why the timing is acting weird.
Here's what I've tried so far -
1. Replaced MAP sensor w/ aftermarket part. No change.
2. Checked coolant temp sensor by Haynes manual method - tested OK.
3. Checked the CKP, CYP and TDC sensors in the distributor, also Haynes manual method (resistance) - tested OK.
4. Checked TPS with analog ohmmeter - resistance varied smoothly, with no abrupt changes over the range (I think max was ~5000 ohms).
5. Tried another (used) ECM - no change.
6. Did the vacuum test for a plugged cat - passed.
7. Tried disconnecting / plugging vacuum from EGR valve - no change.
8. Tested compression - 210/210/210/220.
I can't think of anything else that would cause such strange ignition timing behavior.
Can you help?
Thanks!
Monday, July 2nd, 2007 AT 10:42 PM
2CARPRO JACK
  • 11,533 POSTS
Just for laughs, try your friends DX distributor as a whole unit and see if it does the same
Tuesday, July 3rd, 2007 AT 8:04 AM
BRUCE HUNT
  • 3,754 POSTS
Haven't heard you mention replacing the plug wires. Have a 95 just like yours and it had the miss. Plug wires and whala. Just a thought. Grab them off that friend to see. Thinking out loud.
Tuesday, July 3rd, 2007 AT 8:31 AM
OH95VX
Thanks. Actually the plug wires were replaced a couple of years ago. They look to be in good shape, though I admit I haven't taken an ohmmeter to them yet.
One or more bad wires could certainly cause a miss, so it's worth checking. However, I'm having trouble understanding how a bum plug wire could cause this strange ignition timing behavior, retarding when it should be advancing.
Tuesday, July 3rd, 2007 AT 5:58 PM
OH95VX
I wish I could do that, but I don't think they're interchangeable. The DX uses a TD-41U distributor, and the VX is a TD-42U (same as the Si).
I am considering picking up a boneyard distributor for it, though. Thing is, I hate to just keep throwing parts at this until something makes it work. That gets expensive after a while. ;-)
Tuesday, July 3rd, 2007 AT 6:11 PM
BRICKBRICKVX
I had the same problem. When I tested the fuel pressure is was out of spec and below min requirements. I replaced the fuel filter and the pressure went up a little, when I replaced the fuel pump it went away, and the car runs like a brand new VX. MPG went from avg hwy of 43 to about 58mpg now. Slow up hill went away, and the little missing at hwy speeds went away, and so did the long morning starts. It was hard to get it to fire on the first turn of the key, but everytime on the second turn of the key it would start. Now it starts on the first attempt and fires within the first 2 rotations.
Monday, October 17th, 2016 AT 12:22 PM
