1991 Honda Civic Won't Start
VENENO
i have a 1991 hodda civic with 15000 miles we rebuild the engne 2 yrs ago the timing belt went out last summer i replaced belt and wp and tensioners run great but know i have problem with calr will not run and slow crank i chech spark ok timing belt ok fuel pressure was ok i need to know how to check for codes on this vehicle if you can give me some ideas what to check
May 28, 2007 at 8:15 AM
BRUCE HUNT
  • 3,754 POSTS
Check on the web but there is a connection somewhere under the dash that you can short to get the code by counting the dots and dashes of the check engine light. Don't rule out the EFI relay as a problem. I am curious how you have determined the fuel pressure is fine. The spark is strong and blue? I believe that car has a crank and cam sensor. One of these can be bad but the spark still continues to the car. The timing of the spark is off so far that the car can't start.
May 29, 2007 at 4:40 AM
Suggested Repair
Retrieve diagnostic codes by shorting the under-dash connector and counting check-engine-light flashes. Also check the EFI relay, confirm actual fuel pressure and strong blue spark, and test the crank and cam sensors, since a bad sensor can leave spark present but mistimed so the engine will not start.
Conversation Summary
The owner of a 1991 Honda Civic says it will not run and cranks slowly after a timing belt, water pump, and tensioner replacement. Spark, the belt, and fuel pressure were reported OK. The expert suggests reading codes through the under-dash connector, checking the EFI relay, verifying fuel pressure and spark quality, and testing the crank and cam sensors for mistimed spark.
