1994 Honda Civic Cold Start Moisture
Honda has numerous plugs on the vehicle. One of those could be making a decent connection but the moisture shorts it. Clean them and try one of the electrical get sealants on the market.
Suggested Repair
Inspect for moisture-related electrical shorts: check grounds, spark plug wires, and connectors, and inspect the distributor cap seal for cracks or leaks. Clean connections and apply electrical sealant. Code 43 (fuel supply) was reported later but was not diagnosed by the expert.
Conversation Summary
A 1994 Honda Civic with a JDM D15B engine is hard to start and nearly stalls after sitting in rain, fog, or cold moisture, but starts normally when kept in a garage. The owner noted the engine lacks a purge control solenoid connection. The expert attributed the problem to moisture causing an electrical short and recommended checking grounds, plug wires, connectors, and the distributor cap seal, then cleaning connections and sealing them. The owner later reported code 43, a fuel supply system fault, and asked whether the distributor, oxygen sensor, or fuel pump could be involved; no further expert diagnosis was given.
