1998 Honda Civic Oil Pan Leak
Suggested Repair
Confirm the oil pan leak yourself. If the pan bolts are loose, slightly tighten them with a 10 mm socket and a torque wrench to specification. Check that the automatic transmission fluid level is steady and note when it was last changed; dark red fluid can be normal, but service it if it has never been changed or the level is low.
Conversation Summary
The owner of a 1998 Honda Civic was told during a dealer safety inspection that the oil pan was leaking and the transmission fluid was dark, despite no visible leak and recent dealer service. The expert said automatic fluid is normally dark red, asked about parking-area leaks, fluid level, and last fluid change, and recommended confirming the leak and carefully tightening the oil pan bolts to specification with a torque wrench.
