1994 Honda Civic Radiator Leak
RVANLEU
94 Honda Civic 230K Well maintained. About a week ago I checked the radiator level randomly and discovered that it was quite low. I added plain water as a quick fix, topping the radiator and adding almost to the max level of the reservoir. Last night, after punching it a few times on the highway, my car temperature shot way up and steam began bellowing out from under the hood. I coasted to a safe stop and opened the hood to find that the water in the reservoir was boiling and steam coming from the radiator. After drying what was wet in the engine compartment and waiting 30 minutes, I started the car and limped the final 2 miles home at very low speed. Today when I opened the hood I found that the radiator and reseroir were completely empty. I bought coolant and added to the radiator, but immediately the coolant began leaking out of the \_/¯\_/¯\_/¯\_/¯\_/¯\_/¯ that connects the top of the radiator to the body. Is there a way to replace just the top of the radiator, or seal it so that water or steam does not leak out? Do I need a new radiator? I haven't had any problems with the cooling system up until now, and all the hoses look fine. I appreciate any help.
Mar 8, 2006 at 8:17 AM
FISHERMAN
  • 937 POSTS
yes, you can make it repair, by replacing just the cover and gasket go to the nearest radiator shop and they can help you with that.
Mar 8, 2006 at 1:24 PM
Suggested Repair
Have a radiator shop replace the radiator cover and gasket rather than replacing the entire radiator.
Conversation Summary
The owner of a 1994 Honda Civic with 230,000 miles found the radiator low, added water, and later overheated on the highway with steam from the radiator and a boiling reservoir. After cooling down and driving home slowly, the radiator and reservoir were empty. Added coolant leaked from the upper radiator area that connects to the body. The owner asked whether the top could be replaced or sealed, or whether a new radiator was required. The expert said it can be repaired by replacing the cover and gasket at a radiator shop.
