1995 Honda Civic Head Gasket Oil Leak Fix
Suggested Repair
If the oil leak is from the head gasket, repair it promptly. While doing that work, consider replacing the timing belt, water pump, and oil pump, but first weigh the cost against the Civic's body condition and engine performance. Clean oil from the transmission case with engine degreaser, let it sit, then rinse it with a car-wash wand.
Conversation Summary
The owner of a 1995 Honda Civic with 159,000 miles reports a small oil leak near the head gasket at idle and oil spread across the transmission. The expert advises repairing a confirmed head gasket leak promptly and considering related timing-belt, water-pump, and oil-pump replacement if the car is worth the cost. Oil coating the transmission case can be cleaned with engine degreaser followed by a car-wash rinse.
