1993 Honda Civic Transmission Leak
HIPHOP
i have a 93 honda civic and my transmission is leaking what should I do?
Feb 26, 2006 at 2:46 AM
BRUCE HUNT
  • 3,754 POSTS
manual or automatic? Is it leaking excessively? Check to see if it is leaking around the transaxles if it leaks there then you need to pull the transaxles and put in new seals. Hit any thing on the road?
Mar 3, 2006 at 9:24 AM
Suggested Repair
Check whether the leak is around the transaxles. If it is, remove the transaxles and install new seals. Also note if the leak is excessive and whether the car hit anything on the road.
Conversation Summary
The owner of a 1993 Honda Civic reports a transmission leak and asks what to do. The expert asks whether it is manual or automatic, whether the leak is excessive, and whether the car hit anything. The expert advises checking for leaks around the transaxles and, if found there, pulling the transaxles and installing new seals.
