Honda Civic EX 4cyl. Manual .163,000
KOONTZFAN85
I just found out that my rear engine seal is leaking. They wouldnt even change my oil. I was wondering what something like that costs. Im pretty sure that it is time comsuming because you have to take apart the engine. If anyone has any asnwers that woudl be great. Thank you.
Mar 13, 2007 at 6:24 AM
BRUCE HUNT
  • 3,754 POSTS
The work is about the same as having a clutch replaced with the exception of the clutch parts. I am guessing a couple of hundred dollars. I hope someone else will respond with something more firm. I make this comment that you consider this a good time to replace the clutch as well. Clutch replacement might run around $500 to $600
Mar 13, 2007 at 7:38 AM
