2000 Honda Civic oil gasket pan and the crankshaft front se
2000 HONDA CIVIC
MONKEY13
2000 Honda Civic 4 cyl Front Wheel Drive Automatic 138k miles
I noticed a leak from the front of my car and took it to the local mechanic. He says i need to replace the oil gasket pan and the crankshaft front seal. and Since my car is getting pretty old, he'll replace the timing belt as well.
What is a reasonable cost to get the oil gasket pan, the crankshaft front seal and timing belt replaced?
Thanks for your help.
May 20, 2010 at 5:27 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Depending on Labor Rate in your area, you will most likely be looking at $700 - $1000 parts and labor
May 20, 2010 at 5:33 AM
MONKEY13
Thank you very much obxautomedic!!
The mechanic had given me an $800 estimate.
May 20, 2010 at 6:44 AM
