1992 Honda Civic Won't Start
GORDAN21
  • 6 POSTS
Hi, i have a 1992 Honda civic hatch. 220,000 miles. its automatic 1.5. Lot of miles but dont burn oil runs decent when it runs. I think needs a fuel pump not sure. Somedays turn car over and it starts other times just turns over but wont start. sometimes starts drive it shut it off wont start for a little bit then starts again. This been going on for a few months sometimes no problems other days goes on and off. so i took intake off sprayed some carb cleaner and turn it over and started then stalled did it again same thing. So i guess fuel problem if start when spray carb spray in. What you think?
Jul 25, 2007 at 8:07 AM
BRUCE HUNT
  • 3,754 POSTS
First I think it is the EFI relay. Located up under the dash on the driver side. Common problem. Replace it and things should be fine. BUT to test things out, when the car is not starting, try the spark test to see if the vehicle is getting spark to the plugs. Got spark replace EFI relay if not you are looking at the ignition system.
Jul 26, 2007 at 1:47 AM
Suggested Repair
When the Civic cranks but will not start, check for spark at the plugs. If spark is present, replace the EFI relay under the dash on the driver side. If there is no spark, diagnose the ignition system.
Conversation Summary
The owner of a 1992 Honda Civic reports an intermittent no-start: it sometimes cranks without starting, then starts later. Spraying carb cleaner into the intake made it start briefly and stall, so the owner suspects fuel. The expert recommends a spark test during a no-start; if spark is present, replace the commonly failing EFI relay under the driver-side dash, and if not, inspect the ignition system.
