1979 Honda Civic No Start Fuel to Carb
MAG
Honda, Civic, 1979, 85,000, 1.5 CVCC. I poor a small amount of gas into the carb and it will only run until it consumes the gas that I poured. I have checked the gas lines that come up right before the carb and gas does run all the way just before the carb. It seems like the carb is not getting any fuel. Fuel pump is working fine and the fuel filter looks fine also.
Mar 5, 2007 at 4:00 PM
BRUCE HUNT
  • 3,754 POSTS
You have one of two problems.
Pressure from the fuel may not be sufficient. Solution: Get a fuel pressure check
or
The float and shut off are having problems in the carb such as the needle is sticking to the seat and does not allow fuel in to the carb. The rubber tip gets a ring from the sealing to the seat. This small indentation from being seated can actually cause the needle to stick and not drop open. Solution: Get the carb rebuilt or get a kit and do it yourself.
Mar 6, 2007 at 5:18 AM
Suggested Repair
Check fuel pressure at the carb. If pressure is adequate, rebuild the carburetor or install a carb kit, focusing on a sticking float needle and seat that may be blocking fuel entry.
Conversation Summary
A 1979 Honda Civic will run only until a small amount of gas poured into the carburetor is used up. Fuel reaches the lines just before the carb, and the owner believes the pump and filter are fine. The expert says either fuel pressure is too low or the carb float needle is sticking closed on its seat, and recommends a fuel pressure test and a carb rebuild or kit.
