1995 Honda Civic Airbag Light On
DELFINA AKERS
I have a 1995 Honda Civic with 187,635 miles. I took my car to Midas for a brake job. Midas told me I needed rack n pinion job real bad. I believed them.
When I picked up my car, I could barely turn the wheel. I had to bring it back. I was told when I drove away, that I sucked all the air out and that's why I could not turn the wheel. When they finally flushed and filled the poweer steering, noticed by airbag light was on. Midas could not fix this. They did a PGM test code diagnostic and determined that Midas should take my car to Honda. If the mechanic did not disconnect the electrical and battery, will ths cause my cable reel assmebly to fry?
Apr 8, 2006 at 8:55 AM
BRUCE HUNT
  • 3,754 POSTS
Midas is at fault.
Apr 9, 2006 at 5:51 AM
DELFINA AKERS
Can you provide more information about Midas being at fault?
Apr 11, 2006 at 4:22 PM
BRUCE HUNT
  • 3,754 POSTS
Once they realized that they had screwed up your car, they were then forced to fix it. They were at fault with the overtightness of the steering. You are just driving it after they fixed it and did nothing wrong. Now you take it back and have air bag issues. They were working on the steering and did some damage to your air bag wiring. They should fix it or have it fixed and pay for it.
Apr 12, 2006 at 3:04 PM
Suggested Repair
Return the Civic to Midas and have them repair, or pay Honda or another qualified shop to repair, the airbag wiring or cable reel damaged during the steering rack work. Do not treat the airbag light as unrelated to that job.
Conversation Summary
A 1995 Honda Civic owner had a rack-and-pinion job at Midas. Afterward the steering was very hard to turn until the power steering was flushed and filled, and the airbag light then came on. Midas could not clear it and recommended a Honda dealer. The owner asked whether failing to disconnect the electrical system and battery could damage the cable reel. The expert said Midas caused the problem while working on the steering, damaged the airbag wiring, and should fix it or pay for the repair.
