1993 Honda Civic Transmission Fluid Change
HIPHOP
Hello their i have a 93 honda civic with 98,000 miles on it and should i change my tranmsion oil? Some people told me that is bad if I change it.
Feb 26, 2006 at 2:32 AM
BRUCE HUNT
  • 3,754 POSTS
Change it and the filter. This is the best way to check and see what is wearing in the tranny. You don't want to see many metal shavings. Also, make sure you use the best recommended transmission oil and do not over fill it.
Mar 3, 2006 at 9:26 AM
Suggested Repair
Change the transmission fluid and filter using the recommended fluid. Do not overfill. Inspect the fluid and filter for excessive metal shavings, which can indicate internal wear.
Conversation Summary
The owner of a 1993 Honda Civic with 98,000 miles asked whether the transmission fluid should be changed, after hearing that changing it could be harmful. The expert recommended changing the fluid and filter, using the recommended transmission fluid, avoiding overfilling, and checking for metal shavings as a sign of wear.
