Can some help with this?
SMITHY7861
  • HONDA CIVIC
I have a 1994 Honda civic 5 door. I topped up the clutch fluid about a month ago after the clutch pedal went soft, same thing happened today clutch was going soft I checked for fluid and it was practiculy empty I checked for any obviouse leaks under the bonnet, couldn't see any, Can anyone shed some light on this?
Sunday, November 18th, 2007 AT 3:16 PM
BMRFIXIT
  • 19,053 POSTS
Did u look inside the car by the clutch padel
its simple master leaking or lines or slave
look for the 3 something is leaking
Sunday, November 18th, 2007 AT 3:32 PM
MIKE H R
  • 3,094 POSTS
There could only be a couple of places for the fluid to go. With the fluid running low in a month there is a leak. It is either the clutch master cylinder, the line going to the slave cylinder, or the slave cylinder itself. Look good around the clutch housing and see if you can see any thing that is wet.
Sunday, November 18th, 2007 AT 3:41 PM
