Overheating engine
SHERRYLYNN0774
Okay. Thank you so much!
Tuesday, July 9th, 2019 AT 4:41 PM (Merged)
JORAF
  • 2004 HONDA CIVIC
  • 4 CYL
  • FWD
  • 150,000 MILES
Dear Sir,
My car temperature in not normal. When my engine running for more than half hour temperature goes high of to the Max limit. But sometimes it goes down rapidly which is hard to explain. My motor fan is working properly and normally. And the water in the radiator decreasing rapidly.
  • 31,937 POSTS
Hi there, start with having a cooling system pressure test done this will locate any external leaks, if that is ok, you will need to get the system check for exhaust gasses in the cooling system, a sure sign of a head gasket problem.
Mark (mhpautos)
ANIMALLOVERT
  • 2004 HONDA CIVIC
  • 77,000 MILES
My car is fine while driving, but when I sit in park for awhile the temperature gauge starts to rise. Once I begin moving again it will go back down to an average temperature. I also tried using my heater and the moment I did that it only blew cold air and my temperature gauge started rising. Also, when I drive it sounds like somethings rattling under the hood. Any answers?
CARADIODOC
  • 33,916 POSTS
You're describing multiple problems. Lets start with the most important one first. It's pretty likely the radiator fan is not turning on. The clue is the overheating only occurs when the car is standing still. When driving, natural air flow is sufficient, and the fan is not needed or used. The two most common causes of a dead fan are a defective fan motor, and a fan motor with tight bearings, (also meaning defective motor), but that will draw excessive current and blow the fuse. If you want to try to diagnose this yourself, I'll look at a wiring diagram to figure out where to start.
THOMPSONJDT
  • 2004 HONDA CIVIC
  • 4 CYL
  • FWD
  • 97,000 MILES
I have just changed my theromostat due to my Honda Civic EX over heating. My car was working great for about a week and then I noticed the temp start to rise again. I opened the hood and noticed a low level of coolant in the radaitor, but noticed I had a full overflow resivor? Does anyone know what this is happening? Your help is greatly appreciated!
Thanks,
John
CARADIODOC
  • 33,916 POSTS
Hi thompsonjdt. Welcome to the forum. This sounds typical of a leaking head gasket. If you see the coolant bubbling in the reservoir when the engine is still cool, suspect the head gasket. The best test is what I call the "sniffer" test. Your mechanic will use a glass cylinder filled with two chambers of a special dark blue liquid. Air is drawn from the radiator through the tube while the engine is warmed up and running. If combustion gases are getting into the cooling system, the liquid will turn bright yellow.
Caradiodoc
MSI425
  • 2004 HONDA CIVIC
  • 1.7L
  • 4 CYL
  • FWD
  • 210,000 MILES
I was driving back from Washington to California and my car started to slowly overheat so I pulled over. Popped my hood and coolant was everywhere! I refilled it and my car was fine and was able to drive it over four hundred miles until I got home. Any ideas what the problem could be?
STEVE W.
  • 13,573 POSTS
You would need to pressure test the system to see where it has a problem. It is possible that you have a head gasket starting to fail or it is possible it is just a bad radiator cap. Pressure testing would show you which. You can "borrow" the tester from many parts stores (they basically charge you the price of the tool, when you return it they refund the money).
MSI425
That is what I will do then. I really hope it is not my head gasket. I am hoping it is just the thermostat.
STEVE W.
  • 13,573 POSTS
Hard to say but normally coolant doesn't spew out, then stop after you re-fill. Just fill with water and test, look for a leak. A trick to look for a head gasket issue is to remove the spark plugs, lay them in order side by side and look at them. If they are all the same in terms of color and deposits on the tips iy may not be a gasket. BUT if you find one or two that look really clean you probably have a problem. The steam from the water in the combustion chamber will make a plug as clean as new in a few minutes.
DBUIE23
  • 2004 HONDA CIVIC
  • 4 CYL
  • FWD
  • 130,000 MILES
Why does my 2004 honda civi dx keep
s over heating
  • 31,937 POSTS
Faulty thermostat, coolant leaks, faulty radiator cap, blocked radiator, check these first.
Mark (mhpautos)
TONYNERO
  • 2004 HONDA CIVIC
  • 107,000 MILES
I can not drive. Keeps overheating. I put coolant in and then drove it and it overheated again. Any suggestions?
Tuesday, July 9th, 2019 AT 4:42 PM (Merged)
  • 52,797 POSTS
Start with finding out where the coolant went. Get a pressure test to verify the leak. The fact that you drove it overheated, you may have blown a head gasket. Get a leak down test as well to confirm.
