Low Compression?
Is there anything else I need to do? Like disable the ignition or anything else for testing compression?[/Quote:e08360e9ec]
Go ahead and remove the PGM-FI main relay. Then do your dry and wet check, makes sure you remove all the sparks plugs and mark the wires and also block the throttle plate wide open-[/quote:e08360e9ec]
Can I just hold down the gas pedal all the way when cranking the engine instead of blocking open the throttle? Also when doing the wet test, do you recommend using any special oil like marvel mystery?[/Quote:e08360e9ec]
You cannot be in two places in one time get a helper while you look at the gauge-10W30 will do it.
You need to puff it atleast 5 times[/quote:e08360e9ec]
So is that a yes, it will be sufficient to have a helper press down the gas pedal while cranking and me looking at the gauge?
How much oil am I supposed to put into each cylinder?
Thank you for your responses, I really appreciate it.[/Quote:e08360e9ec]
Have the helper do that
Put oil in a squirt bottle and hit it 5X
Thursday, May 7th, 2020 AT 1:07 PM (Merged)
Find out what's causing that cylinder to be low-could be valves, rings and cylinder wear
Your idle problem will be always there till you fix the cylinder leakage-your running on 3 cylinders
DUKESLOWRIDE
  • 15 POSTS
Is there anything else I need to do? Like disable the ignition or anything else for testing compression?[/Quote:710a27240a]
Go ahead and remove the PGM-FI main relay. Then do your dry and wet check, makes sure you remove all the sparks plugs and mark the wires and also block the throttle plate wide open-[/quote:710a27240a]
Can I just hold down the gas pedal all the way when cranking the engine instead of blocking open the throttle? Also when doing the wet test, do you recommend using any special oil like marvel mystery?[/Quote:710a27240a]
You need to puff it atleast 5 times[/quote:710a27240a]
Thank you for your responses, I really appreciate it.[/Quote:710a27240a]
Put oil in a squirt bottle and hit it 5X[/quote:710a27240a]
I have bled my brakes twice now, and when I press on the brake pedal I still feel it sinking to the floor slowly. Could this mean that my brake master cylinder is bad?
Thanks
ZACK_LEWIS0
How should I find out whats causing that cylinder to be low? I dont wanna just tear into the engine and have to buy replacement gaskets for everything if I dont have to.
Is there anything else I need to do? Like disable the ignition or anything else for testing compression?[/Quote:fc28a70b2f]
Go ahead and remove the PGM-FI main relay. Then do your dry and wet check, makes sure you remove all the sparks plugs and mark the wires and also block the throttle plate wide open-[/quote:fc28a70b2f]
Can I just hold down the gas pedal all the way when cranking the engine instead of blocking open the throttle? Also when doing the wet test, do you recommend using any special oil like marvel mystery?[/Quote:fc28a70b2f]
You need to puff it atleast 5 times[/quote:fc28a70b2f]
Thank you for your responses, I really appreciate it.[/Quote:fc28a70b2f]
Put oil in a squirt bottle and hit it 5X[/quote:fc28a70b2f]
Thanks[/quote:fc28a70b2f]
If your foot is sinking gradually it points to the brake Master Cylinder-
You said the #3 cylinder had a very low compression,
How did you determine this? Doing a compression check or a leakdown test will tell you if its low or normal compression
DUKESLOWRIDE
  • 15 POSTS
Is there anything else I need to do? Like disable the ignition or anything else for testing compression?[/Quote:e4b2754571]
Go ahead and remove the PGM-FI main relay. Then do your dry and wet check, makes sure you remove all the sparks plugs and mark the wires and also block the throttle plate wide open-[/quote:e4b2754571]
Can I just hold down the gas pedal all the way when cranking the engine instead of blocking open the throttle? Also when doing the wet test, do you recommend using any special oil like marvel mystery?[/Quote:e4b2754571]
You need to puff it atleast 5 times[/quote:e4b2754571]
Thank you for your responses, I really appreciate it.[/Quote:e4b2754571]
Put oil in a squirt bottle and hit it 5X[/quote:e4b2754571]
Thanks[/quote:e4b2754571]
If your foot is sinking gradually it points to the brake Master Cylinder-[/quote:e4b2754571]
I just ran the compression test. For the dry test the results were: cylinder1: 195psi (6 cranks) 2: 200psi (7 cranks) 3: 200psi (8 cranks) 4: 200psi (8 cranks)
wet test results: cylinder 1: 220psi (7 cranks) 2: 230psi (8 cranks) 3: 230psi (8 cranks) 4: 230psi (7 cranks).
I know you told me that it should be reading 125-135psi on the dry test. Why do you think it is consistently reading so much higher?
MATRIM01
  • HONDA CIVIC
My 93 honda civic ex has the d16 1.6 liter sohc vtec motor with 185k babied miles. The car was parked for 2 years and only run occasionally but with no problems. It was last started and driven a month ago and ran like a champ but now it turns over but will not start. It's getting fire and fuel so I pulled the plugs and have no compression in any cylinder. I checked the timing belt and it is in good shape and has not jumped time. When I turn it over with the valve cover off the cam is turning, valves are opening and closing but for some reason will not start. Also oil is pooling on top of the head by the no. 4 cylinder and not draining back to the engine. Ther is no coolant in the oil or oil in the coolant so I don't think the head gasket is blown. I am a decent diy mechanic but am stumped by this problem. Any feedback will be greatlly appreciated.
BMRFIXIT
  • 19,053 POSTS
Did you try wet compression?
Mystery oil
Pull all plugs pour some in the cylinder let it sit over night try in the morning
Are you using a compression gauge did u check the valve on it
Make sure gauge in good working condition
Good luck
JESSEBARITONE
  • 1991 HONDA CIVIC
'91 honda civic, 160,000 mi, 4 cylinder. My '91 civic has no power. Friends tell me that its my piston rings or valves. They say it would probobly be best look in junkyards for a newer engine. Does anyone know what engine would be a good choice? A more modern civic engine? I don't know what would fit/bolt on the same way. I know nothing about cars.
BRUCE HUNT
  • 3,754 POSTS
Knowing nothing about cars, if the advice about the engine is correct, I would use the car for trade and pick up a different vehicle. Going to a new engine in that car will cause a number of issues that you are not prepared to deal with and will out of pocket expense break you.
