2001 Honda Civic
MRSJB1979
  • 2001 HONDA CIVIC
Other Category problem
2001 Honda Civic Engine Size unknown Wheel Drive Type unknown Automatic 81,000 miles
My steering wheel vibrates alot when im driving and my car doesn't always start up. Its not the battery because the radio comes on. After a few times it will start
Wednesday, December 12th, 2007 AT 1:22 PM
JUSTIN FREED
  • 87 POSTS
I am going to guess that your steering wheel vibes and the car not starting are two separate issues. So, you should probably pick one (which is most serious?) And go with that.
Incidentally, just because the radio works does not mean the battery is good - it takes considerably more power to crank the engine than it does to run a radio.
I would start with doing a battery check AND make sure all cables etc are connected well. Check charging system as well.
As for the vibe, it really is difficult to say from here - it could be a bearing, warped rotor, unbalanced tire.
Wednesday, December 12th, 2007 AT 1:44 PM
