I would follow up with an ICM(igniter) test. I know you said you swapped icm's but you may have an open wire somewhere and this diag. procedure will ensure the circuit is functioning.
If the coil and ICM are fine, I will then post up a wiring schematic for the distributor where you can check all the proper signals, powers and grounds. And if that is all there then it's most likely a non-serviceable sensor inside the distributor which means you will have to replace the distributor.
But test the ignitor first. Make sure all connections are tight, check fuses, make sure the cap and rotor are in good shape and the wires are properly connected. Then re-check spark. Make sure when you check spark you GROUND the spark plug or whatever you are using to test spark with.
Monday, November 2nd, 2020 AT 1:59 PM
(Merged)
