Power Door Locks Stopped Working?
KHLOW2008
  • 41,814 POSTS
Hi Acrock,
If it is shorted, it will, but if it is an open circuit, faulty actuators would not blow any fuses.
https://www.2carpros.com/forum/automotive_pictures/192750_Civic93CentralLock01b1_1.jpg
Thursday, January 21st, 2021 AT 1:20 PM (Merged)
ACROCK
Thanks for the blow up of the control unit wiring it makes it a lot easier to read. If one of the actuators is bad will it cause the rest not to work or only that door?
KHLOW2008
  • 41,814 POSTS
Hi Acrock,
If the actuator is shorted to ground, it will affect the others, otherwise no.
At the number one or number three of left front power door lock switch, click it to ground and see if there is any activity from the main control unit, (clicking noise of relay).
If power supply from battery input is available and ground is sufficient, the control unit is faulty.
JIM MCLAUGHLIN
  • 1987 HONDA CIVIC
  • 4 CYL
  • MANUAL
  • 100,000 MILES
The central locking is going nuts.
It is opening and closing the door locks its self when driving.
When I lock doors to go some where. I come back to the car and find the locks open.
Seems to hapen more after I wash car or heavy rain.
Think its a dampness problem or water geting on to electrics somewhere.
KHLOW2008
  • 41,814 POSTS
Hi Jim,
Problem should be due to door lock switch. Quite often the switchs gets shorted due to water, etc and the signal would trigger the control unit.
Thursday, January 21st, 2021 AT 1:21 PM (Merged)
JIM MCLAUGHLIN
Hi All,
Thanks very much for reply and advice
Much appreciated
Jim
