Hi coolbaugh2008,
With sparks and fuel available, the engine should start unless :
1. Firing order or plug wires are worngly installed.
2. Engine compression is low. Check the compression, squirt some engine oil into the plug holes after removing them and crank for a few seconds without the plugs.
3. ECU is not signalling the injectors to fire. Try putting some starting fluid into the throttle body.
SPONSORED LINKS
Monday, March 23rd, 2009 AT 1:51 PM
