Engine no start?
REDNECK46
  • 1994 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 194,939 MILES
I have had this car started once, then it has lost its spark I am getting fuel, I replaced the icm checked for voltage at the distributor and I have voltage, I also have good grounds, just no spark. I also checked the coil its good.
Tuesday, May 25th, 2010 AT 4:21 PM
Hi redneck46, Welcome to 2carpros and TY for the donation
Check and test the TDC/Crank angle sensor in the distributor
Saturday, January 2nd, 2021 AT 12:07 PM
REDNECK46
  • 10 POSTS
How do I check the TDC, there are two pickup sensers in the distributor one behind the rotor button and one behind that one
Check the resistances on it and also for short to ground-the fix here if its the problem is distributor replacement.
REDNECK46
  • 10 POSTS
TDC checks good, what else can I check.
What kind of readings did you have on the coil's primary and secondary windings?
Also you need to check the wiring back to the computer for short and open if none found get the computer tested.
REDNECK46
  • 10 POSTS
The readings on the coil were 1.0 and 16000 which is good right. I am stating to think I have a bad computor
Specs-Could very well be the computer
https://www.2carpros.com/forum/automotive_pictures/12900_honda_6.jpg
REDNECK46
  • 10 POSTS
If I have 12 volts on both terminals of the coil it should fire the plugs right.
Put a test light on the negative side of the coil and crank engine over it should be blinking
REDNECK46
  • 10 POSTS
Light stays on not blinking.
Bring the computer in and get it tested
REDNECK46
  • 10 POSTS
I did some more testing on the TDC and the other senser in the distributor, on the ac scale I got a reading of 1.0 on the senser at the bottom of the distributor and.32 on the senser on the top of the distributor. On the ohm scale with the beep I got a reading of.298 and when I turned the distributor shaft I get a beep on the meter when each time the sensers make contact with thier contact wheel.
Earlier I gave you the specs for the TDC/Sensor check the resistances if it out of specs replace the distributor-
REDNECK46
  • 10 POSTS
The specs are low at 298 ohms, comparedto what it needs to be, your specs say it should be 350 to 700. So I should replace the distributor.
Its your shot on the distributor-double check the ignition system
REDNECK46
  • 10 POSTS
What do you mean when you say double check the ignition system?
Everything you have tested or checked came out good in relates to no spark-The TDC sensor didn't make it-my last respond will be to replace the distributor
REDNECK46
  • 10 POSTS
Thank you for your help, car is running great.
