1994 Honda Civic Master cylinder or slave cylinder. Where l
BRIAN5225
  • 1994 HONDA CIVIC
Transmission problem
1994 Honda Civic 4 cyl Front Wheel Drive Manual 114k miles
Over the last few days my clutch pedal has gone closer and closer to the floor without disengaging the clutch. Yesterday, it went all the way to the floor. Called my mechanic and he said to put brake fluid in the resevoir and that I had a leak somewhere. Did that and pumped the clutch for a while. Started working again. This morning, the level was lower again. So it seems to be leaking when the car is sitting. If it is the slave or master cylinders, where are they located on my car?
Friday, June 13th, 2008 AT 11:49 AM
OBXAUTOMEDIC
  • 3,711 POSTS
OK, well you filled the Clutch Master Cylinder, to find the Slave just follow the line from the Master. About 95% of the time it's the Clitch Slave Cylinder that is leaking. However, I usually suggest going ahead and replacing Both.
Friday, June 13th, 2008 AT 7:27 PM
