1990 Honda Civic Squeaky Clutch Pedal Fix
VINBRIN
1990 Honda Civic Wagon 1.5L, 147,000 miles
The c;utch pedal squeaks when pedal is pressed down or released. Sound is coming from inside the car just above clutch pedal. Clutch job done not to long ago.
Nov 16, 2007 at 3:37 PM
  • 31,937 POSTS
Hi there,
The clutch pedal pivots on a plastic bush, this bush may be worn or very dry. The quick fix is to spray a little lubricant up into the pedal pivot, work the pedal a few times so the lubricant can get in. this should fix the problem in the short term, I am unsure as to how difficult it is to replace the bush on this car, but on similar cars it is not a huge job. Best to get a quote first if you feel your not able to attempt it your self.
Mark (mhpautos)
Nov 16, 2007 at 6:36 PM
ROY BYBEE
common,tell how to fix a97chevrolet camaro sqeeky clutch peddal every time I step down on it?????
May 18, 2012 at 2:41 PM
ROY BYBEE
OK 97 chevrolet camaro the clutch makes a whiney sound every time step down on clutch when I am driving it won"t go in gear,what do I do?
May 18, 2012 at 2:49 PM
Suggested Repair
Spray a little lubricant into the clutch pedal pivot bush and work the pedal so it penetrates. If the squeak returns, the plastic bush may be worn and should be replaced; get a quote if you do not want to do that yourself.
Conversation Summary
The owner of a 1990 Honda Civic Wagon said the clutch pedal squeaks from inside the car just above the pedal when pressed or released, despite a recent clutch job. The expert said the pedal pivots on a plastic bush that may be dry or worn, and recommended lubricating the pivot as a short-term fix, then replacing the bush if needed. A later comment asked about a 1997 Chevrolet Camaro clutch squeak, whine, and shifting problem, but no expert reply addressed that vehicle.
