1996 Honda Civic Clutch Pedal to Floor
CIVICHATCHMAN
1996 Honda Civic Hatchback, Miles: 113,000... I dont know much about clutches or master clutches. But i know i went out to my car and started it up then i went to push in the clutch and it went all the way to the floor and didnt come back up and i couldnt get it into gear. But after i sat there and pumped the clutch for awhile it eventually came back. I have to keep doing this after my car sits for like 4 our 5 hours. I was just wanting to know if it was my clutch messin up or maybe there was a leak or air in a hose or something needs bleeded?
Aug 3, 2007 at 2:12 PM
  • 31,937 POSTS
Hi there,
You will have to bleed the clutch, but thats not the main problem, you will have to check the master cylinder (on the fire wall) and the slave cylinder (on the gear box) for leaks and replace which of either or both that are leaking first.
Mark (mhpautos)
Aug 3, 2007 at 4:15 PM
Suggested Repair
Inspect the clutch master cylinder on the firewall and the slave cylinder on the transmission for leaks. Replace any leaking cylinder first, then bleed the clutch hydraulic system.
Conversation Summary
The owner of a 1996 Honda Civic says the clutch pedal sinks to the floor and will not return after the car sits for several hours, so the transmission cannot be shifted until the pedal is pumped. The expert says bleeding is necessary but not the main fix: check the master and slave cylinders for leaks and replace whichever is leaking before bleeding.
