1992 Honda Civic Clutch Pedal Stays Down Fix
Suggested Repair
Inspect the clutch hydraulic system for a leak and replace the small clutch operating component with its spring and rubber seal, then bleed the system. If clutch squeaking or slipping develops, replace the rusty clutch disc together with the pressure plate and related clutch components.
Conversation Summary
A 1992 Honda Civic owner reported that the clutch pedal occasionally stayed down while driving and had to be pulled back by foot. The problem improved after the car rested but returned during continued driving. An expert suggested a weak return spring or linkage needing lubrication. The shop found a leak, replaced a small clutch operating part with a spring and rubber seal for about $3, and bled the system, resolving the pedal issue. Remaining clutch squeaks were attributed to a rusty clutch disc, with replacement of the disc, pressure plate, and related part advised if slipping occurs.
