1987 Honda Civic not sure what this would be.
CIVIC_OWNER
Noises problem
1987 Honda Civic 4 cyl Two Wheel Drive Manual 147k miles
hello, i recently just got back from a trip to Montana and on my way back, i noticed the clutch peddle pretty much become weightless and i found myself forcing the shifter into gears. along with this happening, my steering wheel started making a grinding sound when i turned left and right, i don't know if these two things are connected or what. if any idea's at all, please feel free to write them down.
Aug 27, 2010 at 11:00 AM
  • 75,988 POSTS
Check the clutch master cylinder fluid level, for your grinding noises -check the drive axles CV joints/Boots
Aug 27, 2010 at 11:04 AM
CIVIC_OWNER
i checked the master cylinder and it was at appropriate level of fluid, the clutch is at its proper weight, but i'm still having to force my shifter into gear, and when doing so, it makes a really (metal on metal) sound from the bottom of the car.
Aug 27, 2010 at 11:31 AM
  • 75,988 POSTS
Check the transmission if it has gear oil
Aug 27, 2010 at 11:34 AM
