Wednesday, September 15th, 2010 AT 4:12 AM
Some kid was messing with my daughters civic and it started to run bad found out when you undo the cable not the four wire prong but the cable that runs to battery from the alternator car runs fine thought it could have been a bad diode in the alternator so replaced the alternator and still having the same problem seems like the injectors ar not giving enough gas but like I said soon as I unhook the cable from the alternator and it runs on the battery alone it runs perfect
