Electrical problem after running a bad alternator
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
LOGANL
I guess I was running on a bad alternator for a while, while it was bad all my dash lights stopped working, all windows stopped working except for sunroof, SRS light was blinking and pulsating headlights. Just put in a new alternator, cars running great, SRS light stopped and the pulsating stopped but I still have the issue of the windows and dash lights. Any idea where to start now?
Mar 21, 2017 at 12:19 PM
CARADIODOC
  • 34,414 POSTS
Check for blown fuses under the hood, and inside the car.
Mar 21, 2017 at 12:31 PM
LOGANL
They all test good, checked all wires too and there's no sign of wear. Sorry, should of added that to post.
Mar 21, 2017 at 12:37 PM
STEVE W.
  • 15,418 POSTS
Which Civic do you have? CX, DX? Looks like eight different versions for that year. Also appears to be close to ten fuses for the windows and dash. It is also possible it is a ground but need to know exact vehicle for that. Thanks.
Mar 21, 2017 at 12:55 PM
CARADIODOC
  • 34,414 POSTS
Under the dash is a power window relay. Feel if that clicks when you turn on the ignition switch. If it does, at least one of the passenger windows should work. If it does't click, there is a blown 7.5 amp fuse # 6, also under the dash.
Mar 21, 2017 at 12:56 PM
LOGANL
EX, tried fuse #6 no differance
Mar 21, 2017 at 1:55 PM
STEVE W.
  • 15,418 POSTS
How about a circuit test? Go under the hood and locate the power window fuse in the fuse box on the passenger side. Check it with a test light for voltage on both sides. Now locate the White with Blue stripe wire coming out of that box and check it for power. Next find the relay under the dash and check there for 12+. Turn the key on and check the individual fuses 7,8,10,11 in the under dash fuse panel. If you have power to them the relay is OK, The most likely suspect is a failed master switch.
For the dash lights, Fuse 30 powers all the illumination lights, dash, shifter, heater so if the other lights are working the issue is probably the dimmer control or the dimmer circuit in the dash.
Mar 21, 2017 at 5:48 PM
LOGANL
Is it possible for all the window motors to go bad, because I took door panels off and all motors are getting power when I activate the switches
Apr 22, 2017 at 11:25 AM
CARADIODOC
  • 34,414 POSTS
If you find 12 volts on a wire to a window motor, check the other wire too. If you have 12 volts on both wires at the same time, regardless which way the switch is pressed, you are missing the ground circuit. The best suspect for that is a broken wire between the driver's door hinges.
Apr 22, 2017 at 12:19 PM
