Jun 30, 2020 at 6:24 AM
(Merged)
car loses Power while driving??
ok i had it checked and the mechanic said the pressure was fine and it idles and in park will have good throttle response...until i put it into gear then it bogs right down...what would cause that any ideas?
i have a 1990 honda civic dx hatchback and recently i have been having some starting issues i have fuel and fire but for some reason my car still want start i recently clutch started it and it started and i drove it for about 2 mins max and the it started to bog down and eventually shut off well a couple days before this happend my car started to over heat so the next day i took it to my friends and he put anti freeze in it but he had the engine off and the engine was hot idk what to do plase help
(Merged)
Hi ksartain1,
Check if the sparks are bright blue or dull orange. Dull orange means the ignition coils is weak and failing.
When engine could not be started, test the fuel pressure id sparks are available.
If coolant is getting low, check for leakages, get a pressure test done.
(Merged)
(Merged)
did you scan for codes? also check intake vacuum and if 15" or under suspect a clogged converter.
(Merged)
I have a 90 civic auto transmission. Recently, when the car is cold, it gets up to about 20 mph and the engine revs. It wont accelerate. WHen warm, it does accelerate, but the engine still revs high. I thought I needed a tune up. I got that done, and the replaced the gaskets as well. BUt IM still having the problem. The engine still can rev somewhat, and driving is sometimes hard when accelerating. Any ideas what I mihgt need to fix?
(Merged)
[quote:55a2dd9c48="jules_t97"]I have a 90 civic auto transmission. Recently, when the car is cold, it gets up to about 20 mph and the engine revs. It wont accelerate. WHen warm, it does accelerate, but the engine still revs high. I thought I needed a tune up. I got that done, and the replaced the gaskets as well. BUt IM still having the problem. The engine still can rev somewhat, and driving is sometimes hard when accelerating. Any ideas what I mihgt need to fix?[/quote:55a2dd9c48]
Carb or EFI?
Carb or EFI?
(Merged)
:shock: I have a 91 Honda Civic Dx Hatch 1.6 L and it doesn't seem to have any power left. The plugs are getting covered in oil and the fuel filter has just been replaced. I love my car, but it's been parked for a while due to the lack of power. Thanks so much!
Jun 30, 2020 at 6:30 AM
(Merged)
[quote:8f61da1649="irishgirlsarebetter"]:shock: I have a 91 Honda Civic Dx Hatch 1.6 L and it doesn't seem to have any power left. The plugs are getting covered in oil and the fuel filter has just been replaced. I love my car, but it's been parked for a while due to the lack of power. Thanks so much![/quote:8f61da1649]
Plugs are covered in oil on the outside, or inside the cylinder? If the plgus are getting covered in oil on the inside, you are going to need some major work done. If it is just on the outside, then you may have a valve cover gasket leaking. Not a big deal, but not a reason for lost of power. Do you have a service engine soon light, or engine light on the dash that is lit up? If so, then have the engine code read, and that will lead you to the problem. If not, then it is just a guess as to what is wrong. If your car has high milage, I would check the compression on all of the cylinders and see if it is showing signs of being worn out.
(Merged)
Well.. the service engine light has always been on (and no one can seem to figure out why.. I'm plagued with cars that do this!) but what would result in a loss of power. I was thinking maybe a blow head gasket or something of the sort? Thanks!
(Merged)
[quote:9e2787d2a5="irishgirlsarebetter"]Well.. the service engine light has always been on (and no one can seem to figure out why.. I'm plagued with cars that do this!) but what would result in a loss of power. I was thinking maybe a blow head gasket or something of the sort? Thanks![/quote:9e2787d2a5]
Yes, a blown head gasket can cause a loss of power. But is that the case in this car, I dont know. Are you loosing radiator fluid? Is oil in your radiator fluid? Is radiator fluid in your oil? Is smoke coming out of the exhaust? These are all signs of a blown head gasket. A compression check will most likely tell you if you have a blown head gasket.
You should be able to read the code your self. Do this procedure.
When the CHECK ENGINE warning light has been reported on, turn the ignition ON, pull down the passenger's side carpet inspection flap from under the dashboard, and monitor the LED on the top of the control unit. The LED indicates a system failure code by its blinking frequency.
The control unit LED can indicate any number of simultaneous component problems by blinking separate codes, one after another.
So basically count the number of blinks. If it blinks 6 times, then pauses, then blinks 6 times and pauses over and over, you have 1 code and it is #6. If it blinks 6 times, then pauses, then blinks 12 times, then pauses, then blinks 4 times and pauses, then starts over at 6, then you have three codes. Code 6, 12, and 4.
If you can figues out the blinks, then I will tell you what the code means.
(Merged)
Thanks so much for all the help!
(Merged)
Can I check for this "code" on my 88 honda wagon 4 door?
(Merged)
[quote:e817e0b3c4="mtnharmony"]Can I check for this "code" on my 88 honda wagon 4 door?[/quote:e817e0b3c4]
for your wagon, use this method.
Without Scan Tool
How to Display and Read Diagnostic Trouble Codes
In the event of a PGM-FI system malfunction, a dash mounted indicator lamp will illuminate and stay On. When this condition occurs, it will be necessary to check the ECU LED display to diagnose PGM-FI system malfunctions.
When the dash mounted indicator lamp is illuminated, remove the right door sill molding and small cover on the kick panel, then pull down the carpet from under the dashboard to expose the ECU. Turn on the ignition switch and observe the LED on top of the ECU. The LED will indicate a system failure code by blinking frequency and two second pauses.
As an example:
One blink, followed by a two second pause, followed by one blink and another two second pause indicates a failure code 1.
Two blinks, followed by a two second pause, followed by two blinks and another two second pause indicates a failure code 2.
The ECU is also capable of indicating simultaneous failure codes as follows:
One blink, followed by a two second pause, followed by two blinks and another two second pause indicates failure codes 1 and 2.
Without Scan Tool
As an example:
(Merged)
i have a 1990 civic 1.5L with high miles i was told that the passenger side tie rod was going to need replacing, it was not done. Today while while shifting from 2nd to 3rd i lost power and it sounds like the driver side half axel fell off. I pulled off and took it out off gear checked it out its still connected but now the car will not accelerate at all. iI put it into 1st to continue driving but did not go any where in any gear. There is a grinding/ knocking sound comming from the passenger side half axel and while putting in gear the passenger side will spin and grind. While towing the car home with Tow rope i noticed the same noise. While over looking the engine i noticed that i can still shift gears but there is no power from engine to wheel. Is all this because of a bad tie rod or do i now need to replace the passenger front axel as well. :(
Jun 30, 2020 at 6:51 AM
(Merged)
sound like the axle is bad, get it up on a lift and check to see exactly where the grinding and knocking is comming from. it sounds like the front axle. also check the bearings.
(Merged)
I would say that a cv axle has disengaged from the tranny. The cause is what you need to find out. Look at the motor mount by the tranny as problem as well.
(Merged)
thx for the info i will check all suggestions and update if needed
once again thank you to all
(Merged)
Hi i have 1992 honda civic dx carburator engine and have problem with rpm not becoming stable at idle condition and it drops to 0 (zero) and the car shuts off when i'm wainting at a light or when shifting gears as soon as i push on the clutch to change the gear the RPM goes to zero and car shuts off also i smell some gasoline smell from the engine room plz help me out.
Aug 8, 2020 at 4:31 AM
(Merged)
Hi yasirk45,
You would need to check the idling system and find out if there are any vacumn leakages.
Is it a single or twin carb?
(Merged)
🔧 Tools & Auto Repair Parts
Find automotive tools, diagnostic equipment, and replacement
parts for your next repair.
Shop on Amazon →
