1997 Honda Accord Vibration in Reverse
RYN996
1997 Accord EX 2.2L VTEC, 5 speed, 113,000 miles. My car vibrates when I turn the steering wheel to the right (it's done it while driving from 20-60mph) or if I go in reverse quickly. I had the CV axel on the passenger side replaced about 15,000 miles ago. I looked under the car and the drivers side CV axel is leaking from the boot. I assumed the replacement CV axel on the passenger side went bad but now that I've seen the drivers side axel leaking I'm not sure. Thanks for your help.
Jun 11, 2006 at 5:58 AM
BRUCE HUNT
  • 3,754 POSTS
Anytime the CV boot breaks down you will have problems. Generally, unless you are there right away to replace the boot, the joint is headed quickly to a failure. If the boot is bad and you are having problems, it is time to replace the other side.
Jun 20, 2006 at 12:42 AM
RYN996
I have since replaced the drivers side cv axel and the vibration is still there. Always when moving in reverse quickly and every once in a while when going around a right hand turn, no matter the speed. Thanks for your help.
Jun 20, 2006 at 4:57 AM
BRUCE HUNT
  • 3,754 POSTS
Have you looked at the brakes to see if they are heating up especially on one side. My next though was on wheel bearings but I don't think so. Are you feeling these vibrations through the steering wheel?
Jun 20, 2006 at 8:30 AM
RYN996
I haven't looked at the brakes. I feel the vibration more in the seat of my pants or floorboard area. I thought it was coming from the right side but when my wife was in the car and felt it she thought it was coming from the middle of the car. Also, I've noticed that the faster I'm going the more intense the vibration is and as soon as I but on the brakes it stops.
Jun 20, 2006 at 3:34 PM
BRUCE HUNT
  • 3,754 POSTS
All the more reason to look at the brakes. Applying the brakes causes it to rub as a constant rate. When the brakes are not engaged it could be one of the rotors is bad.
Jun 21, 2006 at 9:02 AM
Suggested Repair
Inspect the brakes and rotors for uneven heating or a damaged rotor. The vibration is felt in the floor and stops when the brakes are applied, which points more to a brake or rotor issue than the replaced CV axles.
Conversation Summary
A 1997 Honda Accord vibrated when turning right and when reversing quickly. The passenger-side CV axle had already been replaced, and the leaking driver-side axle was later replaced, but the vibration remained. It was felt mainly through the seat or floor, became stronger with speed, and stopped as soon as the brakes were applied. The expert recommended inspecting the brakes, particularly for a bad rotor.
