89 Honda Accord DX automatic transmission that shifts violently when put into reverse
Sep 16, 2007 at 7:51 AM
WRENCH
✓Experienced Mechanic
Here is a couple of things to look for, is your engine idle speed to high, if not then check fluid level if its too high and you have not added any look for coolant mixed in, if foamy drain and refill then check for coolant. If its just too high (maybe someone put too much in) then drain to spec.
