1995 Honda Accord Transmission Smoke
MICHAELMALLIN
1995 Honda Accord LX 4Cyl 102,000 miles. Driving on a road trip today I noticed the car was smoking when I pulled over for gas. Smelt like burning oil and I noticed a couple of small (half dollar) oil puddles on the group under the car. I assumed the car was leaking oil and checked the oil level......slightly low.....took 1/2 quart. Called mechanic and he told me to keep a close eye on the oil level and bring in Monday. ON the way home the car revved up to 5000RPM in changing b/w 3rd and 4th. I also noticed that each shift was slightly more rough than usual. Realizing that thiat may have been trany fluid and not oil I pulled over to check the fluid. The car was not smoking and the transmission dipstick was dry. Car took 2 quarts of transmission fluid and drove home fine. Do Hondas have any particular place they might leak transmission fluid? If would have to be somewhere hot enough to burn and smoke. I didn't think transmissions typically leak fluid.
Apr 7, 2007 at 12:45 PM
BRUCE HUNT
  • 3,754 POSTS
The transmission can leak just like any other device. There are weak spots. For instance, the shafts that drive the front wheels turn out of the transmission and it is simply a seal that retains the fluid. One of those could be leaking and the oil could splash or land on the exhaust system. While moving the air currents could relocated the dripping oil to the exhaust and there you get the smoke and smell.
Try putting a clean piece of cardboard under the vehicle and note the location of any drips before you move the cardboard. Simply look up from the drop and locate the source.
Apr 8, 2007 at 1:22 AM
Suggested Repair
Check the front axle shaft seals and other transmission leak points. Place clean cardboard under the car, note drip locations before moving it, and look upward to find the source, especially fluid that can reach the exhaust and smoke.
Conversation Summary
A 1995 Honda Accord smoked and left small puddles on a trip. The oil was only slightly low, but the transmission dipstick was dry and the car took about two quarts of fluid; shifting had also become rough and the engine revved high between gears. The expert said transmissions can leak at weak points such as the front axle shaft seals, and fluid can splash onto the exhaust and burn. They recommended placing cardboard underneath to locate drips and tracing upward to the source.
