1996 Honda Accord Battery Drain
LEMONADE62
I have a 1996 Honda Accord LX with 79000 miles on it and a 4-cylinder automatic engine. My problem is that the car keeps killing batteries. I have put two batteries on it in the past two months and it killed them both. Now, it won't start without being jumped off. And after being jumped, it will run until shut off and then won't start again. Battery cables were replaced, as were the ends. Connections were checked and found to be fine. Alternator was checked and found to be fine. Don't know if related or not, but turn signals also will not work when the air outside isn't hot. But work fine when it's a warm day. I have had two different people work on it and neither seem to know what the problem is. Any suggestions?
Jun 9, 2007 at 4:35 PM
BRUCE HUNT
  • 3,754 POSTS
I say it is the alternator. It can have a short or a voltage regulator with a short. It is probably unable to stop charging the battery and kills it from over charging. That one is hard to find as the alternator appears to be running proberly but does not know when to stop.
Jun 11, 2007 at 6:52 AM
Suggested Repair
Have the alternator and its voltage regulator tested for an internal short that keeps charging after the battery is full. Replace the alternator if it cannot stop charging, even if a basic output test looked normal.
Conversation Summary
A 1996 Honda Accord LX with about 79,000 miles repeatedly kills batteries and will not restart after being shut off unless jumped. Cables, ends, and connections were checked, and the alternator tested as fine. Turn signals also fail in cooler weather but work when it is warm. The expert says the alternator or voltage regulator may be shorted and overcharging the battery even though it appears to charge normally.
