1988 Honda Accord Idle Over-Revving
AMYGDALA18
my '88 honda accord has over 200,000 miles on it. i just replaced the radiator and all the hoses last year and have been getting regular oil changes. when the weather started getting cold, the engine started revving between 1000 and 2000 RPMs while idling. sometimes when i engage the clutch, it will rev up as well, but not when i'm driving. i'm due to get my fuel filter replaced but i don't know if that will fix it. i have carb cleaner my mechanic has used on it before but he seemed stumped as well as to what it might be. any ideas?
Dec 29, 2006 at 4:24 PM
BRUCE HUNT
  • 3,754 POSTS
What are we talking about for a fuel system? Is it injected or carbed?
Try looking at these things. Idle air control valve. Take it off and take it completely apart. Clean it and replace it. Then bleed the coolant system completely of air. See how that goes. Then try looking for vac hoses that need to be replaced. After that, the air flow sensor on the throttle body could be sticking. Another cause is the EGR valve and finally you could have a leak in the intake manifold or the intake manifold gasket.
Dec 30, 2006 at 1:28 AM
Suggested Repair
Remove, disassemble, clean, and replace the idle air control valve, then fully bleed air from the cooling system. Also inspect and replace leaking vacuum hoses, check for a sticking throttle-body airflow sensor, test the EGR valve, and look for an intake manifold or gasket leak.
Conversation Summary
The owner of a high-mileage 1988 Honda Accord reports idle speed fluctuating between 1000 and 2000 RPM after cold weather began, sometimes also rising when the clutch is engaged but not while driving. Recent cooling-system work and regular oil changes have not resolved it, and a fuel-filter replacement is pending. The expert asks whether the fuel system is injected or carbureted and recommends cleaning and replacing the idle air control valve, bleeding the coolant system, then checking vacuum hoses, the throttle-body airflow sensor, the EGR valve, and the intake manifold and gasket for leaks.
