1991 Honda Accord High Idle
KNBOND1
  • 10 POSTS
My 1991 Honda Accord Ex coupe with 142500 mi and manual transmission has a problem. I just got through cleaning the throttle body and that was it and replaced the Idle Air Control valve and now it ildes too high. When it is cold or hot or with the a/c on or off, it ildes at 1500RPM respectably. What is the problem with this high ilde? Thank you.
Apr 26, 2006 at 3:45 PM
BRUCE HUNT
  • 3,754 POSTS
When you cleaned the throttle body you probably removed a screw that is located around the throttle cable. That screw, not the allen adjustment on the linkage is the idle set. Check a maintenance manual for exact location.
Apr 28, 2006 at 6:17 AM
KNBOND1
  • 10 POSTS
Thanks, I got it.
Apr 28, 2006 at 8:24 AM
Suggested Repair
Recheck the idle-set screw near the throttle cable, not the Allen adjustment on the linkage, which may have been disturbed while cleaning the throttle body. Use a maintenance manual for the exact location and reset the idle.
Conversation Summary
A 1991 Honda Accord EX coupe with a manual transmission idled at about 1500 RPM hot or cold, with the A/C on or off, after the throttle body was cleaned and the idle air control valve replaced. The expert said the idle-set screw near the throttle cable, rather than the Allen linkage adjustment, was likely disturbed and should be checked using a maintenance manual. The owner confirmed the issue was resolved.
