1995 Honda Accord Bumpy Idle
LAUNCH890
i have a honda accord 95'. it has a very loud and bumpy idle and low speeds, it also runs like crap with a/c on and often will stall at a stop with it on. can this be a vaccum leak? and if so, where?
Sep 18, 2006 at 3:47 AM
BRUCE HUNT
  • 3,754 POSTS
If the idle is screwy all the time warm and cold start with coolant level and bleed the system. Then if that does not take care of it check for vacuum leaks on the intake manifold and gasket. Smoke bomb in the intake will find the culprit.
Sep 26, 2006 at 6:07 AM
Suggested Repair
If the rough idle occurs both warm and cold, check the coolant level and bleed the cooling system. If that does not fix it, inspect the intake manifold and gasket for vacuum leaks using a smoke test.
Conversation Summary
The owner of a 1995 Honda Accord reports a loud, bumpy idle at low speeds, poor running with the A/C on, and stalling at stops with the A/C. The expert advises checking the coolant level and bleeding the system, then inspecting the intake manifold and gasket for vacuum leaks with a smoke test if the idle problem remains.
