2003 Honda Accord Idle Vibration
JOEY11
Yesterday,My girlfriend bought a 2003 honda accord with 51,000 miles on it.Weve noticed that when we start the car and its on park it vibrates.I dont know if thats normal for a honda thats barely 3yrs old.Also when I drive it and come to a stop on the road with the break pressed it vibrates as well and sometimes shakes a little bit.Any help please before I take it to a shop.I dont know if its a major problem or minor.
Jul 9, 2006 at 12:17 PM
BRUCE HUNT
  • 3,754 POSTS
Try noting what the tach is reading. You could be idling to low. This really sounds minor in nature. How does it feel when it is running down the highway?
Feb 21, 2019 at 5:10 AM
JOEY11
Just wanted to say thanks for the reply.If the idle is to low is that whats causing the vibration on the car,and if so where should it be at.I took it to the dealer and they said it could be the throttle body,which i doubt because the throttle has nothing to do with the vibration right.Please help before I waist my time going back to the dealer going back and forth.
BRUCE HUNT
  • 3,754 POSTS
The car should idle at a steady 750 rpms. Dropping and idling below that is not good for the engine and will cause vibration. Stating that the throttle body in bad is really quite a simplistic answer. There are many variables of sensors and such on the throttle body.
Suggested Repair
Check the idle speed with the tachometer. The engine should idle steadily at about 750 rpm; a low or unstable idle can cause vibration in park and at stops. Do not replace the throttle body based only on a simplistic diagnosis—related sensors and idle controls should be checked first.
Conversation Summary
The owner of a 2003 Honda Accord with 51,000 miles reported vibration in park and shaking when stopped with the brake applied. An expert said the issue sounded minor and advised checking whether the idle was too low, noting a steady 750 rpm idle. The dealer suggested the throttle body, but the expert said that was an overly simple explanation because many sensors and variables affect the throttle body.
