2000 Honda Accord Fan Speed 1 Out
MIKEEUNICE
Need help on this problem I have. The fan speed selector switch for the air conditioning is not working on setting 1. It works on 2 to 4.
Thanks,
-Mike
Jun 3, 2006 at 6:08 PM
LOSONE
  • 1,616 POSTS
It is more than likely the blower resistor. A switch is a rare failure.
Jun 4, 2006 at 12:40 AM
MIKEEUNICE
[quote="losone"]It is more than likely the blower resistor. A switch is a rare failure.[/quote]
What part do I need to replace to fix the problem?
Thanks for the response...
-Mike
Jun 5, 2006 at 9:39 AM
Suggested Repair
Replace the blower motor resistor. A failed fan-speed switch is uncommon for this symptom.
Conversation Summary
The owner of a 2000 Honda Accord V6 reported that air conditioning fan speed 1 does not work, while speeds 2 through 4 do. The expert said the blower resistor is the likely cause and that a switch failure is rare. The owner then asked which part to replace.
