1997 Honda Accord AC Not Cooling
MTREJO64
I own a Honda Accord Sedan LX 97. The AC was working fine but it gradually stopped blowing cool air. Everything works fine (The compressor engages) I just don't get any cool air. If I just need to add freeon, can I do it myself. Any advice would be great. Thank You
Jul 30, 2006 at 2:42 AM
MIKEYBDMAN
  • 623 POSTS
[quote:3e8f735efe="mtrejo64"]I own a Honda Accord Sedan LX 97. The AC was working fine but it gradually stopped blowing cool air. Everything works fine (The compressor engages) I just don't get any cool air. If I just need to add freeon, can I do it myself. Any advice would be great. Thank You[/quote:3e8f735efe]
You can get one of those servicing tools from an autoparts store and add a can of freon to see if that helps. The only problem is without having the proper equipment, you wont know if it is properly serviced or not. If you havent had to have it serviced since it was new, it might be time to spend $100 and get it properly serviced.
Jul 30, 2006 at 11:32 AM
Suggested Repair
A parts-store service kit and a can of refrigerant can be tried as a test, but the charge cannot be verified without proper equipment. If the system has not been serviced since new, have it professionally serviced.
Conversation Summary
The owner of a 1997 Honda Accord says the air conditioning gradually stopped blowing cool air even though the compressor still engages, and asks whether refrigerant can be added at home. The expert says a store kit and a can of freon can be tried, but proper equipment is needed to confirm the charge, and a professional service is advisable if it has not been serviced since new.
