When idling my a/c will not blow cold, blows very cold while car is moving. Even if I hold the rpm around 2000 the a/c still won't blow cold. Also if I am driving with a/c on and roll the window down the a/c vents start blowing out fog and the air gets warmer. Secondly at idle only with the a/c on the car will start to overheat, if I turn the a/c off the temp stays well into the normal range. No check engine lights. Compressor belt does squeal only at start up if the a/c is on. At idle I can hear the compressor coming on and off. Compressor is less than one year old. Radiator is also less than a year old. Whatcha got?
Oct 11, 2009 at 1:28 PM
