1994 Honda Accord Overheats in Traffic
ACHUCK30
I have a 94 Accord and it is heats up only in heavy traffic.
1. I check the radiator fan and it works, but it only comes on only when the A/C is on. What controls the radiator fan to turn on?
2. The condenser fan will come on only if I tap it with something. Is the condenser fan going bad?
Thanks in advance.
Nov 8, 2006 at 8:32 AM
VF-XX
[quote:fb8b2e104d="achuck30"]I have a 94 Accord and it is heats up only in heavy traffic.
Thanks in advance.[/quote:fb8b2e104d]
You might check the fan relays in the fuse box. I had one go bad and stick closed this spring.
Nov 9, 2006 at 12:42 AM
ACHUCK30
You might check the fan relays in the fuse box. I had one go bad and stick closed this spring.[/quote]
I switch out the relays and it tested ok. A friend thinks the condenser fan is going bad because I have to tap on it to get it going. I am looking to purchase one for a good price, is it difficult to install? Do you know of any good websites that I can purchase and may assist in installation. Thanks again for your help!!!
Nov 9, 2006 at 4:05 AM
BRUCE HUNT
  • 3,754 POSTS
Four number 10 or 12 bolts and the fan is loose. Detach the wires and pull it out. There may be a someother items that fight your process but it is fairly easy. The part is shorting if it runs when you tap on it. Parts yards online have the fan.
Nov 9, 2006 at 6:28 PM
Suggested Repair
Replace the condenser fan; starting only when tapped indicates it is shorting. Removal is fairly easy: remove four No. 10 or 12 bolts, disconnect the wires, and pull the fan out. Radiator fan relays were already swapped and tested OK. Online parts yards carry the fan.
Conversation Summary
The owner of a 1994 Honda Accord said it overheats only in heavy traffic. The radiator fan runs only with the A/C on, and swapping the fan relays showed they tested OK. The condenser fan starts only when tapped. The expert said that means the fan is shorting, replacement is fairly easy with four bolts and a wiring disconnect, and online parts yards have the part.
